Bt Doctur
- Aug 29, 2004
- 19,413
locate the center of the pin ,can be done visually
Drill in 3/8 ths of an inch with a #3 drill bit for 1/4 x 28 thread and tap .
using a 3/64 drill bit CAREFULLY drill approx. 3/4 to 1 inch into the housing until the magnet picks up steel shavings.STOP DRILLING. Install grease fitting.inject grease until you see it between the steering yoke and transom.
