cmk245
- Jun 8, 2012
- 29
I'm sure this has been answered before, but cannot find info on this subject.
I have a 5.7 engine from a 1987 boat with closed cooling full, system (San Juan MC305) Full System. It was using ONLY the stern drive pump for water.
I have read several posts on having to use engine driven raw water pump for full closed system, and re-route hose from drive to overboard to cool drive.
I HAVE a complete raw water pump setup with all the brackets, pulleys, and belt. But I would have to purchase the correct hoses to make this work.
The heat exchanger is the large SJE model (25"x5"). I spoke to SJE, and they said that the exchanger was designed to work with the stock Alpha drives water pump. So I am confused on if I should leave it as ,or install a thru-hull and strainer in my hull and use the belt driven pump.....
Engine is out of the boat now, and NOW would be the time to do this. I DO NOT want to find out after install that it overheats at idle., due to not enough water flow.....
ANY Help will be Appreciated......
Thanks,Charlie
Thanks,Charlie
