should my bilge pump only run if there is water to pump out, I turn the switch on but it runs constantly, never shuts off.
I have noticed a number of people concerned about the float switch sticking and draining the battery. I do my own maintenance and do check the area around the bilge pump for debris however, in more than 50 yrs of boating I have never had a float switch stick, mabey just lucky or mabey the preventative maintenance I don't know, but I will always have an automatic float switch for the just in case moment.
So I'm just a worry wart about automatic devices, switches, dashboard/instrument lights and other potential battery drains....we camp on the boat in some remote areas so a dead battery is a concern. I'm confident the automatic float switches are generally dependable....
The new type of float switches actually have no float to get stuck. They work on the principal of change in inductance of a coil when its surrounded by air vs water. No moving parts.
Nice idea!You guys that are worried about a pump draining your battery, there is a simple "flow switch" you can plumb into the discharge line. If no flow of water to "close" the circuit it won't energize the pump, like what the oil injection systems have.
