Pcolafisher
- Jun 26, 2013
- 188
Pek,
Looking absolutely outstanding!
Cheers
Cheers
Thanks for all the kind words. They are greatly appreciated!
I've made a lot of progress in the past few days. I got the motor control all ready, with the electrical harness and the throttle/gear wires through the seat backs and organized running back to the transom. I think I may have gotten control wires that are a foot or two longer than needed, but better that than too short. I also got the steering wires and pulleys rigged up. Once the motor is in place I'll need to make a few final adjustments. I've got some pictures I'll post a bit later.
I started working on the windshield. I discovered that the curvature of the deck is a bit more than the windshield can handle. So now I'm trying to come up with a pair of shims that follow the windshield base to level it out a bit. We'll see how that turns out. Anyone have any other ideas? It is made of plexiglass so not sure I would be able to cut the curvature into it. I really don't want to crack it!
pekdtrom, I don't know what part of your wiindshield isn't fitting right, but being plexiglass does mean you can trim it and make it fit. You could use a die grinder with a few 2" rolloc discs in different grinds and basically sand the edges to fit. To help from any splits while trimming use masking tape on both sides. Just an Idea.JMHO
Hmm, ok, I could try to grind off a bit in the middle. The following pictures I think gives a better idea of what it looks like. In this picture it is just sitting on top of the deck and you can see the gaps on each side better.
Ok, I'm probably more comfortable carefully grinding at it. What would I cut it with? A jigsaw? Or some kind of handsaw? There are 4 holes along the front for screws going through small rubber grommets. I guess I can just drill up new ones as the arch would either get too close to the middle ones or remove them completely?
I have cut plexiglass and even Lexan materials with most anything that you would use to cut wood.
I have cut plexiglass with my table saw, chop saw, and even a bandsaw without any problems what so ever. I would apply the masking tape to make sure you don't scratch the plexigalss while trimming it.
If you have a fine tooth blade for your jigsaw, you could try it and see how that works. Just remember, it is a plastic type compound and if you cut and heat up the material, it can reseal itself after the blade passes by. So slow speed blade movement is a better idea.
And if you are looking for a very smooth edge after you cut it, you can use a blow torch and flame treat the edge to make it smooth as if it was never cut. But be careful if you decide to do that. It doesn't take much heat to warp the edge either. It is a learning curve type issue.
If you go the grinding route, use whatever you have and see how it cuts and removed material as you go. Again, it is all a learning experience issue. But if you approach each method with respect, you will be okay.
Remember, you started this project not knowing basically anything about boat building, and you built a very nice boat. So use that same mental experience with this as well. Slow and easy to get the feel. JMHO
