chuckdodge
- Feb 22, 2016
- 2
I am doing an engine swap on an old truck with a 318 and would like to have a v8 in my boat. The boat is a 1969 IMP. It currently has the 160Merc in it. Has anyone here tried putting a Chrysler 318 or 360 (theyre the same for all intensive purposes) in a mercruiser set up boat? I realize the bolt pattern on the bell housing will be different but is the shape similar enough to where I could drill or somehow alter the bell housing to bolt up? will the output shaft bolt up to it? if not do you know of an output shaft that would bolt up to the engine and be compatible with the outdrive? I also realize that I will have to change prop and upper gearing and exhaust and front engine mounts and plenty of other things, Im mainly worried about getting it bolted to the outdrive.
