FrankenCub
- Dec 29, 2015
- 296
Gotta agree with Watermann, just get it over and pull the engine and drive so you can replace the transom and floor. Do the major stuff first and you will feel much better about the whole process. Each big part knocked off the list is a big jump
The little piddly stuff is just treading water. If all your mechanic said was the engine was bad because of loss of compression in one cylinder, I'd question his judgment. Did he say why it was lost ? Did he tell you the numbers for all 6 cylinders ? If you have 5 with realy good compression and one without, it is possible that it has a valve hanging up. If one isn't closing you'll never get it to build compression. Pull the valve cover and plugs, rotate the engine manually. Watch the valve springs for movement and note if that cylinder is moving less, or at all. Probably best to look for signs of a cracked block first, right under the exhaust manifold. Plenty of examples here in the SC section. Then move on to watching the valves.
