87 15 HP Evinrude - 50 psi on both cylinders - runs great
Hezekiah
Hi guys:
Just checked my compression on my motor and it's registering 50 psi on both cylinders. The motor runs great...very strong.
I cleaned the carbs a couple of weeks ago...could I have slightly messed up the timing and it's effecting the compression test?
Thanks.
ondarvr
Timing has no affect on compression.
There are several reasons it could be read that low.
1. Using a pull rope to get a compression reading typically leads to a lower number because it's harder spin it quickly.
2. Gauges are known to get very different readings, and the difference can be sizable.
3. Method used, different people can get different numbers on the same motor.
5. Maybe it is that low, but still runs OK.
Hezekiah
Ok, it is a gauge from Harbor Freight...so maybe it's a lower quality piece of equipment.
Also, it is a pull start...boggles my mind. Such a great running motor, never thought it would read that low
I appreciate the response. 👍🏻
Hezekiah
Only problem I think I might have is when i try to sell it - nobody is going to want a motor with compression that low.
ondarvr
You still don't it's that low, and most people won't check the compression.
boobie
Do a GOOD decarb on it and then recheck the compression on it.
JoshKeller84
before you try anything else, since youre using the HF gauge, try a different attatchment than the screw in plug. Use the press in one, and I bet your compression will come up significantly. the hose they use on the screw in plug is not large enough diameter to allow ample air flow - the push fit adapters are larger.
Hezekiah
Ok, thanks for that - I will try to locate the piece you're talking about. You think an auto parts store should have it? Or dare I get one from HF?
JoshKeller84
read the reviews - go to the negative ones. lots of them are reading way low - as is the one I have. Its a design flaw in the hose connecting system.
Hezekiah
Yeah...you're right. I'm reading them too...makes sense. There is a lot of hose to travel.
Hezekiah
There are so many bad reviews...I might as well junk this thing....now convinced it's the compression tester.
AlTn
if the large brass quick connect fitting will unscrew from the gauge hose, will the threaded portion now fit the spark plug hole?..if so...try fitting it with an oring and retesting...both spark plugs removed and pull until the gauge indicates its highest pressure < needle quits rising >
Hezekiah
I was looking at it this morning before I went to work to determine the same thing. To me it looked like different connections - but I will look at closer after work.
Bullie
I went through 3 of the HF compression gauges before I gave up and bought one from Auto Zone. It doesn't look as cool or have as nice a carry case as the HF gauge but it works. I could never get the HF gauge to get above 60lbs on any engine.
Hezekiah
Yeah...most stuff from HF I can work with...this I could not...I should have read the reviews online first...
Bullie
Wish I had. I have some decent tools from there but some of it is just junk. I think you will be pleasantly surprised as to how much compression your motor is actually producing.
Hezekiah
Yeah, I expect it to be over 50 PSI...that's for sure
