Hello everyone:
New day - new problem...at least it's the weekend.
So I purchased an old 25 HP Evinrude, short shaft Tiller. I put it on a 1963 14' Richline.
When I get going in the water it ventilates severely when it gets up some speed. I took it back to the guy I bought it from; we did a water test and they said it was the prop. 1 guy there said it was a worn out prop that had slightly lost it's shape and that's what was causing it to ventilate. This was a sunday, on Monday - he discussed it with his boss and his boss said it was a spun hub...regardless....needed a new prop.
I ordered a new prop and it arrived yesterday. I put a OEM Johson/Evinrude, 11 pitch prop on it, as recommended by the owner of the shop where I got the motor (one of the props also recommended by **********).
Today - I take it out to water test it...and it is doing the same thing. You can definitely tell it has a new prop on it...it idles better, smoother in the water...but as soon as it gets up to go on plane it ventilates.
Here are some pictures of the setup and the lower unit. (MORE TEXT BELOW PICTURES)
These pictures to show how motor is sitting in relation to the bottom of the hull - seems perfect.
This picture to show how the motor is setting on the transom - it is also bolted with 2 bolts in addition to the clamps
This is part of the ventilation plate that is bent - could this be causing it?
Another slight bend in the ventilation plate.
When I talked to the guy at the shop where I got the motor from today (not the owner), he recommended a put a hydrofoil on it. I have one...and I'm ok with putting it on...but when I just purchased this motor...I would like to not have to rely on a hydrofoil.
Note: I just had a 15hp Evinrude mounted in the same exact position and it did great in the water....no ventilation.
Any input or recommendations?? I find myself once again scratching my head...
Edit: I took a video when I was on the water earlier - don't know how much help it will be...it's not that great...will try to take a better one tomorrow when I have someone with me....
https://www.youtube.com/watch?v=u3kwZjvroTY
