I am replacing the transom on my jon boat. Plan on getting 3/4in ply and coating it with epoxy. What epoxy should I use? Do I epoxy the ply to the boat? Or just use the bolts to hold it together?
Epoxy IS the absolute Best sealer for your transom wood. And it is the most expensive method. If you use it you want to use marine grade epoxy like this. U S C O M P O S I T E S
HARDENER>>
Epoxy with 3:1 Ratio Medium Epoxy Hardener (Description)
