fireman749
- Mar 5, 2016
- 3
Need help. I was dewintering my 2000 chaparral 280 SSI with twin Volvo Penta 5.7 SX I/Os. Port motor started up and ran fine. Starboard would not do anything. Checked all battery connections first and they were fine. Checked breakers all around motor and they were good. Checked breaker under starboard ignition switch and it was popped. Reset it and turned motor over but they fuse popped again within 15 sec. Switched the fuse with another identical fuse on the charger. Same results. Reset and tried again. Same thing. When i reset the breaker it blows within 15 seconds wether I am trying to start the motor or not. Fuel pump never comes on when I reset the breaker and turn the ignition on. The motor ran perfect when I winterized it in December. Pulled the boat about 30 miles to have some bimimi work done but he didn't touch anything electric or ever attempt to turn the motors over. Any suggestions on where to begin looking would be greatly appreciated. Is it possible one of the hot wires on the starboard motor gauges came off and is shorting it out?
Thanks,
Craig
2000 Chaparral 280 SSI
Twin 5.7 Volvo Penta SX
Thanks,
Craig
