I am trying to get my freshly rebuilt motor to run. I have great spark on both cylinders. I believe my carb is the culprit and needs some tweaking. I have read how to set the lean/rich adjustment knob. 1.5 turns out from gently seated. My question is does it look right? In the picture below I have two washers on either side of the lean/rich needle spring. Both washers came in my carb rebuild kit. In the exploded parts diagram it shows these two washers where I have them. However, when I turn the needle in to "gently seated" the spring appears to be over compressed. Just wondering if it looks okay to ya'll or if the washers are wrong and I have the needle turned to the incorrect spot.
I will try to start it as soon as it stops raining...Rebuilding outboards in your apartment has its limitations...:cold:
Thanks in advance!
Thanks in advance!
