goblerblaster
- Dec 26, 2011
- 180
OK, this motor was supposedly running great, then died from a gas tank full of water. I took the carb off, cleaned it, put in a new float, and float needle- I did not pull the knock in plugs but did spray carb cleaner through all the orifices I could find. Reinstalled carb and motor will start and run for a few seconds and die like it is running out of gas. I unhooked the fuel line at the fuel pump, squeeze the bulb and gas squirts out. I then unhooked the gas line that feeds the carb, squeezed the bulb and gas squirts out. I can pump the bulb and it gets firm, choke the motor and it will start and run for a few seconds and die. I can wait about 10 minutes and not do any bulb pumping and it will start on first or second pull, then act like it is running out of gas, I can pull the choke lever in and out and keep it running for maybe 10 or 15 seconds and then it will die. After it dies, I can't get it to start unless it sits for 10 or 15 minutes. Then it will start and repeat the above described process.
What is this an indication of ? Before I pull the carb again, I thought someone might have an idea.
When it is running, it is not missing at all.
Thanks
Thanks
