 The question doesn't make as it is. You left out a word. I am guessing that you wanted to know if they turn in the same direction. The answer to that would be yes unless it is a counter rotating motor. Those are not real common and usually only used on older twin engine setups.Its cheating when you answer a question with a question. What is the answer?
There was never a 3.0l installed in a vehicle that is the same as the one in boats.Ok guys sorry I did not catch my mistake.Thanks for the answers. A ford mechanic told me that and I decided to ask the people that would know. So I can install a chevy 3.0 4cylinder block to replace a 3.0 omc.
Thanks guys So Scott you are saying a 1980s block is the same as a 1990s block ?
