I don't have access to volvo us website but on your US website try searching under clicking this link won't work. Marine Drives & Transmissions > SX-A; DPS-A; DPS-B; DPS-B1; DPS-A OXi; DPS-B OX; DPS-B1 OX; FWD; SX-A 1.43; SX-A 1.51; SX-A 1.60; SX-A 1.66; SX-A 1.79; SX-A 1.89; SX-A 1.97; S > Transmissions or XDP-B; TSK X-B; TSK X-BLT; TSK XHP-B; TSK XHP-BLT; TSK XXP-A; TSK XXP-ALT; TSK XXP-D3; XDP-B 1.78; XDP-B 1.95; XDP-B 2.32; XDP-B-D3 2.11; XD
Then under trim pump. It's way easier, and accurate if you had a transom serial number. Or even an engine number to look up all 3 serial numbers. I don't know if that search feature is available on the US consumer website though. I've seen links from the website and it seems better than what we have access to here in Canada.
Yegboats, Just so you are aware, The link you provided earlier is/was for Volvo dealers use only and is password protected...Your dealer I believe should have something similar though.:encouragement:
If one should click on the link in my signature line below, it will take you to Volvo's parts which is powered by iboats....
http://www.volvopentastore.com/
cptbill, Here's your engine parts,
http://www.volvopentastore.com/Marin...view_id.765176
And your drive parts,
http://www.volvopentastore.com/Marin...view_id.765076
But in order to help find the correct trim cylinders and hydraulic trim hoses you will need your Transom Assembly model number. The number may resemble or may even be like the one in the following iboats link. His number is TSK Sx-MLT....
http://forums.iboats.com/forum/engin...ic-hose-repair
If yours is the same number then here would be the parts guide you're looking for.
http://www.marinepartseurope.com/en/...t-7746040.aspx
But you need to confirm your transom model number to try and help ensure we're looking for the correct parts. Also write down and post your serial numbers just in case
Yegboats has access to Volvo's website as it may help too.:thumb:
