Ok. So I recently aquired a 85 starcraft bowrider 17' for the most part I think the boat is in good shape and engine runs great. But while replacing the carpet I some floor damage at the back behind the drivers seat. (time to get out the saw). After removing the floor on that side I found damage to the last 3 feet of the stringer (time to get the saw BACK OUT). I cut out the bad section of the stringer, which is 1 x 6 re shaped a new 1 x 6 to fit exactly into where the old one came out and cut another 1 x 6 to sandwich next to it from the back of the boat 2 ft past the cut ( I can only add wood to one side because of the gas tank.
Now with my back story in place here's my questions
I resined and screws the 2 pieces together, how do I attach the new stringer to the transom. Do I use screws( really didn't want to screw into that unless I was really suppose to) I was going to just glass over the whole thing to hold it.
Also how long do I need to let the resin between the 2 pieces sit before sanding the thing and classing it to the boat
