bought a second hand 1999 Rinker 180 with 3.0 Merc cruiser and alpha one drive. I have a single battery setup. When I bought the boat, I removed the battery and stored it indoors for the winter. I have not used the boat. I went to hook the battery up last weekend and I inadvertently hooked both ends of the trim motor to the positive battery terminal for a few seconds. It smoked and I removed the cables. Everything in the boat worked before hand (radio, horn, starter engaged) After my screw up, the boat was completely DEAD, and I searched and found an inline fuse at the red battery selector. The fuse is a 30A, 250V glass fuse and it was burned out. Thinking I got lucky, I bought another 30A fuse but only a 32V at autoparts store. When I replaced the fuse, something electrical (bilge?) worked for about 3 second, and then the fuse burned out. Could the fact that I used a 32V fuse be an issue? Why in the world would a 250V fuse be used in a 12V battery system? I am having a hard time finding a 250V fuse, but I will get one. Do you think I could have fried the trim motor? Is there another set of fuses beside the dash and the one on the top of the motor?
Thanks for any insight on my knucklehead move.
