Battery and stereo questions
thumpar
That seems pretty fast with just a stereo. I have an amp and stereo in mine and go for hours and still start the 5.7l.
KD4UPL
Sounds like the battery is weak. But, how big a battery are we talking about. How "much" stereo are we talking about? If you've got several amps and you left it a full volume I could see it draining a battery.
roffey
My boat is in my garage/workshop and I put the radio on and listen for hours and do it numerous times over the winter and do not have problems for spring start up.
spoilsofwar
If the linked head unit and pair of speakers drained your battery in two hours to the point where it wouldn't crank the motor over, then yes, your battery was not healthy to begin with.
Just to make sure, I'd charge the battery fully on a charger, and test again. Since you didn't mention the state of charge the battery had to begin with. Outboards, older ones especially, aren't always the best at charging batteries.
For perspective, I've ran my stereo (two amps, 6 speakers, 1 subwoofer) off of a group 34 odyssey battery for at least four hours and probably more, and then used it to crank my boat's engine right up. So something is definitely not right with your setup.
64osby
Age is not a true indicator of battery health. Test it before charging. Give it a full charge. Let it rest a few hours or overnight then test it again.
I run two separate batteries in the Mariner. Motor, lights and bilge pump on one and everything else off the other.
redneck joe
Yeah I've got two in the Carver with same set up. Thanks for the chart I'll test it out.
