snowman246
- Oct 13, 2015
- 193
Welcome to the board!!!! A first boat is something special you will always remember.
CHECK YOUR BILGE PUMP!!!!! Go over every nut, bolt, wire, etc. Better to find it at home than on the water. On any boat I purchased from someone else, I always run the water hose over the entire boat and verify the water is coming out of the drain hole in the bilge and not the bottom of the boat hull (this is an easy way to make sure there are no leaks in the boat itself).
I verify the bilge pump looks good and is working better. As a golden rule, I always install a second bilge pump as a last resort. I personally could care less if my engine dies on the water-its happened plenty of times. I want to make sure water coming in has a way to be pumped out without my help. Fire extinguisher, horn or whistle, small tool kit.
Most of all safety first. Life jackets, throw cushion, anchor etc. Take a friend who has a boat to the lake with you the first couple times you launch it. Its easier to wave them over and have them tow you back to the dock then sit on an empty lake with no help in sight.
