ib18
- Mar 2, 2013
- 489
how does motorguide 70b 24v cable connect with the steering Rack gear? I think mine is broken, please HELP!
Motorguide pro series 70 pounds thrust (foot controlled) - 24 volts
Serial # 95010270 with 52" shaft - a big motor
foot control model # - MLP300652
I bought it used and found out too much spin in the motor when in water. I opened it up and noticed the cable and the steering Rack gear is separated. I tried to stick it back but I think there should be something to lock the cable with the steering rack gear. It may be broken by previous owner because the stainless steel shaft was bent badly. Maybe it broke the cable from the steering rack gear.
Is there a screw to hold the 2 pieces together? Thanks
I cannot see from the picture below.
