I bought a 2009 Yamaha 150 HPDI 2 stroke from the original owner and put it on a used Stratos bass boat I bought from the original owner, but different person than the motor.
I put a Yamaha control box and hotfoot with new throttle and shift cables on the boat.
The motor runs strong and smooth up until I get the hotfoot to a certain position, almost to the wide open position, then the motor loses power.
If I let off the hotfoot just a little, the motor picks back up and runs fine again. If I never press the hotfoot to that certain position, the motor never misses a beat.
I get about 60 to 62 mph at 5200 to 5300 rpms before the problem occurs. I am not looking for more speed, but I am concerned about damaging the motor.
This is what I have done so far to eliminate the problem, with no success:
Changed spark plugs
Changed VST filter
Changed Strainer above VST tank
Cleaned the filter behind the VST tank
Changed fuel filter in under cowling water separator
Changed basket filters on high pressure fuel pump
Changed basket filters on injectors
Sync & Link and adjust TPS according to Yamaha service manual
Checked resistance of spark plug caps. One is about 5.8 but still in spec, all others near middle of 4 to 6 k ohms.
Remove fuel tank from boat and clean it
Verified vent line is clear
Remove anti siphon valve from pickup tube
Remove screen from bottom of pickup tube
Cut bottom of pickup tube at a slight angle on bottom
Replace fuel line from tank to motor
Replace primer bulb with Yamaha brand bulb
Replaced 10 micron water seperator assembly and filter in bilge
Replaced the shift position indicator switch under the cowling. It had a crack in a wire near the switch.
Purchased YDS and cable and monitored fuel pressure at the high pressure pump. It stayed right at 700 psi and did not drop when the problem occurred.
There are no trouble codes in the computer.
I am about to remove the injectors and send them off for cleaning and testing.
I am considering adjusting the stop bolt on the hotfoot so it will not travel far enough to hit the problem spot, but it is driving me nuts knowing the motor should not be doing this.
I have seen many posts on this forum with similar problems, but none of them match this one exactly, at least not that I can find.
I welcome any suggestions you may have.
Changed spark plugs
Changed VST filter
