Bad bearing or is the outdrive trying to engage when in neutral
kccoe
What could the prop noise be ? When spinning prop in neutral. Forgive me for the ad prior to my video it will play after.
muc
sounds like there isn't any oil in the drive.
kccoe
The link wouldn't open.
Any metal shavings or water in the oil?
No metal shavings and gear oil look new. Removed lower
Unit and could not pulled prop shaft out and bearings out. It has
A lot of salt buildup . Even broke gear puller when trying to disassemble the lower unit internals. The boat has about 180 hrs in salt water.
kccoe
Update bad bearing and found a small amount of shavings when I flushed drive.
