Just got a new project boat with twin bravo 3's and when I looked in the steering lever hole/transom cutout and seen mounds of rust and debris (on both drives). Is there any possible culprit besides a bad steering pin seal? I?m asking because there is absolutely no play in either ring side to side or up and down which leads me to believe the bushings are fine. I don?t mind replacing the pins since I?m pulling both engines and I?ve replaced a ring in the past. Just want to make sure I?m fixing the correct problem, the only other cause I think of was a leaky transom seal which I?m probably replacing if I can?t fit my wrenches in the cutout (which is unusually large). So do steering pin seals usually go bad if the bushing is fine?
Thanks,
David
Thanks,
David
