eyebrowski
- Nov 5, 2013
- 7
I picked up this OB (SN 3931109) not running and in need of a little work (gummed carb, kinked fuel line, wrong spark plugs, water pump). I got this all taken care of and it is running great on the bench with one exception, I can not get the motor to shift into any gear.
With the lower end off the shift lever moves freely and linkage rotates down to the lower end. The prop spins and I can manually turn the shaft on the lower end and get the lower end to shift into F-N-R. BUT, when I bolt it all back together I can not move the shift lever.
When reassembling I assure that the shift lever and lower end are in the same position (eg, forward, neutral, reverse). Any thoughts?
