Sharkbaite
- May 8, 2009
- 26
I am working on a Rinker Rocket Jet boat that I purchase a year ago and have been replacing all the top end end electronics IE Stator, Trigger assembly due to the Magnets coming off the flywheel and eating everything.
I finally have the boat running and noticed the Tach doesn't work. I checked my connections to ensure the ign wire and ground are good, and just for giggles I put a volt Ohm meter on the Sender wire and I reach voltage there and as I rev the engine the voltage climbs, so obviously I am making it back to the ignition module, or do I have a problem with the module?
I went and bought a used meter just to see if it was mine or not, and that meter shows the same signs as the original one, IE with ignition off, the needle moves to about 2-3 on the gauge, and when I turn the ignition on the needle drops to 0. and as I start the engine you can see the needle move abit, but never reads.
