I'm new to site and need some ideas on a problem with my girlfriend's boat (2007 Princecraft Vacanza 220 - 2007 Mercruiser 5.0 220 HP). A screeching sound occurs when I take the boat out of gear, especially while idling but also just before clicking into neutral. The sound is identical to the sound made when trying to start a car that's already running. If I cut the engine, the sound goes away (obviously) but when I start it back up...no screech. I can idle just fine when starting up but once in gear and back to neutral...SCREECH. The boat is running superb. All the gauges show healthy function. I still can't tell exactly where the sound comes from because the boat was covered in kids yesterday when it started (tubing!). However, from what I was able to hear, it did sound like the screeching starts inside the engine compartment around the middle/top area followed by a grinding noise lower in the compartment...if not outside the boat in the stern-drive area (that only happens if I let the noise continue; which, I only did twice). If it is helpful to know...I had a fresh full tank of gas, the boat has been out in heavy rain and required bilging (not submerged flooring or anything serious), the sounds doesn't happen EVERY time but more often than not I am hearing it, and again...we were tubing.
