Tilt/trim oil change
Old Crow
I have a 2004 Yamaha F115TLRC and I would like to change tilt/trim oil.
​Can you point me in the right direction to get started?
robert graham
The tilt/trim is a closed hydraulic system and should not need the fluid changed....Dexron II or Yamaha tilt/trim fluid to add for leaks....
robert graham
I believe that some folks have actually tried to bleed/drain the tilt/trim fluid as a preventive maintenance item but I've not seen it....and if the tilt and trim is working fine then maybe just as well to "leave that sleeping dog lay"....
