I have a 2003 sea ray bowrider with a mercruiser 4.3 with an alpha outdrive. I took the boat out it started right up went about 100 yards and she quit. I spent about an hour cranking it, going a few yards and then dying again until i got back to dock. When i got home she wouldnt crank period. I checked for voltage at the ignition coil and there was none when hooked up. When i removed the positive and tested it connected to nothing there was voltage while cranking. So i replaced the ignition coil and still will not crank. I tested the voltage at the ignition coil and still no voltage hooked up but when removed positive from coil and tested it had voltage again. I did pull the spark plugs and they weren't firing either. Everything i know and opinions of the automechanics i know point to the icm. But i would like to verify everything before dropping 4-600 bucks on the ignition control module. Any ideas or other possibilities?
