turbocorrado
- Aug 14, 2013
- 251
so my boat is a 97 wellcraft eclipse, 4.3 v6, my timing isnt advancing past 23 degrees. the ignition is a stupid hybrid year. the distributor doesnt have counter weights, it doesnt have knock sensors. it has an ecu thats supposed to advance timing. i have the purple/white grounding wire to set timing. last season the boat felt like it had no balls and wouldnt rev past 3600, when we timed it last year we didnt ground the wire to do "base timing" tonight i tried doing it and im only getting 23 degrees at 2500 rpm, we have base timing set at 10 degrees
relevant info:
~PO told me he sunk the boat twice, and he never ran it after the last time it sunk - he waited till after it was in my name to tell me this, i bought it in july of 2014
~i ran it for 2 months the way i bought it. it would never rev past 3700, if i floored it with the trim down it would go about 3300rpm at 32mph, when i trimmed up i could get 3700rpm and 37mph out of it.
~i rebuilt the motor in feb of 2015 after finding that the motor had 2 cylinders with 90 psi, we set timing to 10 degrees without grounding out the purple/white connector. i ran it all of 2015 like that, it would rev to 3600 no matter where it was trimmed and topped out at 36-37mph
relevant info:
