timing not advancing, unique issue, ideas please
FreeBeeTony
yeah i know, im kinda wondering if im getting the added acceleration spark advance on top of the base timing setup.
​I'm wondering how you can ask this question when in post #14 you state that you're getting 24* of total advance? Are you actually measuring the total advance?
jimmbo
Have you ever checked to see if the carburetor is opening fully when you push the throttle lever?
turbocorrado
havent had a chance to check while cruising, i got the 24 degrees at 2500rpms in my driveway. i was expecting to get higher than 24 degrees which is why i made the thread, i didnt realize the v6 ecu was only supposed to advance 14 degrees, i was expecting it to advance another 20 degrees or so, also i have yet to find a timing chart for a thunderbolt v 4.3. ive only found thunderbolt iv for 4.3 - all the thunderbolt v charts are v8's - i wasnt sure initially what system i had as the engine doesnt have knock sensors so it was throwing me off
on another note, i went back to the basics with it, even though it was running smooth all the time, just underpowered/wouldnt rev out. and i pulled the plugs, found cyl 3 plug was really black and somehow the gap got messed up at some point, it was only about half of what it should have been. so i re-gapped all the plugs and also made the discovery that i had never replaced the wires after i bought it.... i was 100% sure i replaced them when i did the cap and rotor but apparently not. so i also replaced the wires. im splashing the boat one evening this week, (hopefully tomorrow) so i will get to test everything out then
