dshannon11
- May 20, 2016
- 2
Hi, new to the forum and new to owning a boat. (I have been around boats my whole life)
Recently bought a used 2005 Lowe 202 Trinidad with a Mercury 50 HP 2 stroke motor.
The previous owner used the boat as a ground for his electrical work so I took the opportunity to rewire the accessories and add a second battery with the "Add a battery kit" from BlueSea.
So the only items hooked up to the batteries are: the motor, the accessories line I ran, and a 16awg wire for the helm console gages/lights (I assume factory).
With that said, Last night I hooked up the battery kit and ran a 4 AWG pos/neg wire from switch to the helm for an Accessories fuse box.
I ran 18awg wire from the fuse box to new LED docking lights (Nilight 2 X 18W 1260 lm Cree LED Spot Driving Fog Light LED - $17.99)
Upon turning the LED lights on, the FM stereo immediately got quieter and fuzzy. Turned Lights off, and radio worked again.
What are my options? is this a grounding issue or are the LEDs putting off RF?
Tonight I will run the lights off a separate battery to see if its through the lines or airwaves.
Can I fix either situation or did I just by crappy cheap LEDs?
A separate unrelated issue, The stereo was bad so I replaced it with a Sony marine headunit. It appears to vibrate a little. Is there a way to prevent this?
Thanks
Dylan
Thanks
Dylan
