I've been trying to diagnose an ignition problem where my boat will try to start while it is already running. Even if I turn off the engine and leave the key in the "run" position it will eventually/sporadically start up on it's own. I'm thinking this is probably the ignition switch itself so I'd like to try replacing it to see if that helps. Could someone identify the ignition switch based on these photos? It is a turn key ignition (without push choke) that goes to a 2007 Mercruiser 5.0 220hp 305.
Also, bonus question, what is the small button located aft of the engine compartment blower switch?
