First, Welcome Aboard
I have a 1990 sun toon 20 i just purchased it has a 90hp mercury force. I can not read the serial number. It has a 14x11p prop on it but it goes really slow at full speed and dranks gas. Any ideas on why and if prop is right size?
most pontoons go really really slow, and drink gas. in fact, most run the same speed with a 30hp as they do a 90hp motor (they just used more fuel with the bigger motor) that is the downfall of a displacement hull
however BEFORE you ever assume its a prop issue, have you done the basics?
have you done a compression test?
is the motor's anti-cavitation plate just below the surface of the water, or is it well below that?
how do you have your motor trimmed?
Now, assuming the motor is not too deep, you have a decent angle of trim, what is the speed you are getting in RPM, and what is your GPS speed?
