ondarvr
- Apr 6, 2005
- 11,527
Well guys, I think my warm start problem might be solvedI was talking to a mechanic at our new marina and he told me that pushing in and *holding* the ignition key on this type engine actually injects a small amount of fuel into the engine. Holding it in does not do anything further - you get just one squirt of gas while it's held in. On a warm engine, where the gas has probably evaporated, you need multiple shots of gas. Simply push in the key multiple times to prime engine, then try to start it. I had mistakenly been under the assumption that when key was pushed in I was choking the engine using good old butterfly valves (I think that's what you call the plate, right?). Maybe some engines work that way, but this one injects fuel. I wonder how many other folks are fooled by this?
Your mechanic is only partially correct, and doesn't really understand the primer valve. It is not a pump that squirts fuel, it's just a valve that opens, the only pressure is supplied by squeezing the bulb. Once you push the key in you get one squirt of fuel until pressure builds again from either squeezing the primer bulb, or from the motor turning over and the fuel pump supplying pressure. That's why I explained a couple of methods on how to start it in my prior post, these methods will force fuel into the motor itself.
