Chris.ChrisCraft.03
- Jun 14, 2016
- 6
Hi All, I have an increasing Problem. Third year of owning this 2001 Chriscraft with Volvo Penta 5.7GXI-A .
First year one odd stall as I down throttled the boat. Never happened again, didn't think much of it.
Second year, Increase in frequency but did not happen all the time. Focused on the battery connections , which seamed to have the affect fixing the issue. Until the issue happened again. It happen maybe a third of the times we had the boat out.
Third year ( This Year) First time I had the boat out no issue, but the driving style may have abated the issue ( since it only happens at low RPM after it's been running). Have had the boat out two more times and it has happened both times and repeatedly.
Now here's What I know (or think I know) and how it happens (to the best of my knowledge):
- It does not stall on the initial boat around the lake, only after I have shut the engine down for anchoring or kids water sports.
- It does not happen at medium to full throttle or even moderate throttle. only at low rpm while motoring around.
- It has always restarted after a period of time. Not always the same amount of time. shortest a few minutes . longest 15+- minutes.
- When it happens all power to engine gauges and starter is gone, until that period of time is up, that allows it to start again.
- I still have power to the blower and boat accessories ( ie Nav Lights). But electrical power to anything engine related is dead.
- I did notice that my volt meter spiked to Zero at one point, but due to higher engine revs no stall. But Then Last Stall, I was watching and saw the Volt meter again spike to zero either just prior or in concert with the stall.
- I have replaced the battery terminal with no effect on the issue.
- It appears to be increasing in frequency.
Any Help would be greatly appreciated- Thanks Chris
