How it works at auto zone is you buy the tool and return it when you are done. If you use a credit card it charges it and refunds it in 24 hours
Changed 3 gimble bearings in 2 different boats with the slide hammer from my auto zone....works like a charm every time.
Be sure to get the bigger one (I forget the weight of the slide) I tried using a small 3lb slide I had and it was basically worthless in this case. I pounded that small hammer for 10 min and the bearing barely moved. I went and rented the Big slide hammer and got it out in 3 shots.
