Engine # 0w339318 Drive # 0w584139 Boat never operated in salt, total hours on engine are around 250, hour meter states 350 hrs but shop who replaced drive left key on for over a week and a half an killed both batteries and caused meter to count non running hours. History on boat, complete new SEI drive installed by dealer at end of last season due to upper gear failure. Took boat out one time this season all was well, ran for maybe 1 hour total. Last time out ran for 30 minutes parked for a couple hours went to restart and within 1 min heat alarm sounded and shut engine down and was towed back. Tried to run it on muffs and no flow to engine. Removed drive replaced a faulty impeller which had failed where the collar was bounded to the rubber impeller. (Note that impeller looked fine, just collar was no longer bounded to impeller. I also replaced thermostat with a 140 stat from West Marine as they did not have a 160 in stock. I inspected the hose near the gimbel housing, and found no kinks or damage.) Now, put new impeller I have flow to engine I back flushed hoses from T stat housing down to power steering oil cooler, and from oil cooler to outdrive, there was no debris in any of the hoses. I flushed drive while it was off and flow was good. Put boat on muffs and engine temp slowly starts to heat up at idle. I figured I am going to put in the water and test in real world environment. At idle engine slowly (within 5 min of idle speed 500 to 900 rpm no wake speed) begins to heat up 200 + degrees and alarm will sound , as soon as rpm's reach 1000 temp goes right back down to 150-160 as per the gauge. I ran boat from 1k rpm to 4800 rpm for 1hr + and temps never went higher than 165 degrees. (I did NOT IR temp test the T stat housing, but to the touch it is hot. Is it possible that the water pump (I believe the term is circulation pump) mounted to the front of the engine is not circulating enough volume of water to help coal the engine at idle? I searched multiple threads including Nauticool's lengthy post with a similar issue, but his issue seemed to revolve around an mismatched drive/engine combo. I am an ASE certified automotive tech so I have a sound understanding of engines, but this one is really stumping me! Any help you guys could offer would be greatly appreciated. I am getting ready to jump ship over this
and buy a new Yamaha 242 Limited S and say "sayonara" to Mercruiser entirely, but my wallet really wants me to stay put
