bruceb58
- Mar 5, 2006
- 30,799
You pack both bearings manually and fill the hub with grease when you install the hub. If you didn't put grease in the back bearing, it won't get grease from the buddy bearing. It's only purpose in life is to keep the hub pressurized. If you leave cavities of air in th hub, those may leave and then you will add some more grease through the buddy bearing but once the hub is full, you will never need to add more.So the grease will still get back to the back bearing ??
