Ok fellas I'm at my wits end, I have 30ft carver santego with twin Volvo penta AQ271C engines, 280 out drives, I'm gonna start from the beginning here. Port engine has been fine since beginning of June. Starboard side I rebuilt carb (Holley 4150) got it dialed right in, starts and idles and runs perfect even under load. So I think all is good, fill the gas tanks and all the sudden port engine will not go above 2500rpm with load on it, will rev in neutral perfectly. So I pulled the Holley and did a rebuild on it, put it back in dialed it in and starts on a dime and idles perfect, take it out put it under load and it's great up to 2500 rpm then it won't go any further, if I give more throttle the Rpms will drop. I have replaced the fuel filter also. Any ideas or direction would be greatly appreciated, my question is this a fuel delivery prob? Carb prob, I know that carb is good, it runs a lil rich at idle. Could it be a bad fuel pump, or pickup screen from running the tank low. If anyone has any tests or theory's I would love to hear them, I'm all out of ideas
