My new to me 225 outdrive does not go forward. I have looked on the forums and found a little on how these drive work and some testing. I have 12 volts to both forward (green) and reverse (blue) wires when lever is shifted. When I check at the connections just before wires go into outdrive both wires have 12 volts when in forward and reverse positions. When the connections are not hooked up (just outside the outdrive) one has 12 volts and the other is dead. Shift to other position and the other wire has 12 volts and the other one is dead. Are they both supposed to be hot when in gear?
Also how do you check the ohms of the coils. I checked ohms through both wires going to out drive and got 2.8 ohms. Did I do this right? Thanks for any direction and help. I acquired the boat this way.
