nwaccstudent@yahoo.com
- Jul 17, 2016
- 1
I recently bought a 2011 stingray with 4.3 Volvo with 13 original hours on it (it sat for a couple years). It starts and runs, but takes forever to plane out (30-60 seconds). Once it planes out (somewhere around 2800-3000 rpm), it has a very responsive throttle, runs great, lots of power. It tops out at 4000 - 4200 rpm, but it should run up to 4600-4800 at WOT. I have replaced the fuel and fuel filters, I have run two tanks of fuel with sea foam fuel treatment as well as putting lucas fuel treatment directly into the fuel filter (50-50 ratio with fuel) and there has been no change in performance. It also is flooding after it sits for a few minutes between run times. I have to use the fast throttle feature while cranking to clean out the fuel chamber before it will start again. This is a fuel infected engine. I would be interested in some advice on how to address this issue. Thanks!!
Donny
Donny
