Hello,
New to this forum and I'm hoping to get some help with my boat. I have a 2005 Glastron with a Volvo Penta 5.7 GI-E
We have been having a loss of power issue. The boat will run perfect for a minute even at full throttle and then all of the sudden we loose power, it feels like someone throttled back. Sometimes it will even backfire. When we feel the loss of power, we go into neutral and we here a whine and it is coming from the smaller pump in the front of the assembly. Eventually the pump stops whining and returns to normal. We can then go right into full throttle no problem and then the same problem will repeat.
We noticed that the electrical connector going to the smaller pump is extremely hot to the touch. Even the wires are hot to the touch. We were thinking that the pump is acting up as soon as it heats up and when it cools off runs fine. We have replaced the filter and all with no luck. If the smaller pump was going bad would it cause this extra load on the wires?
Also, is it possible to change the front small pump alone?
Thanks for any help! Hoping to get this figured out soon.
John
John
