Scott06
- Apr 20, 2014
- 7,033
Attached is a photo of my spark plugs, not sure if these are ok or a tad lean, any advice is appreciated.
They are off my 5.0 Vortec that I repowered (21 ft Sea Ray 200 Sport, previous owner cracked original 4.3). Has a Michigan Motorz partial engine package including 1409 carb, cast iron 4 bbl intake ( allegedly a cast iron copy of Edelbrock performer- they grind the manufacturers name of them), thunder bolt v ignition.
Originally the plugs looked lean- almost white. I swapped the stock metering rods for a .065 X .037, put in the pink 7" metering rod spring, and the .33 accelerator pump nozzle (thanks Rick). The metering rods should be 1&1/2 stages richer on cruise mode, 2 stages richer in power mode. Acceptor pump nozzle really smoothed out the off idle bog when hitting WOT holeshot. FWIW I'm running a 5.0 Gen+ igntion module 10 deg base, total advance seems to be about 26 deg at 3800 rpm.
No real performance issues, pulls hard when tubing, skiing, or wakeboarding even with 7 people in the boat. Lugs a little bit when I make a quick turnaround to pick up a skier in the water, warm restarts after sitting are slow some times. I just not sure if I'm rich enough, haven't heard any detonation. What do you guys think of how the plugs read? Any advice on this, the lugging, and restarts would be appreciated.
Thanks
Thanks
