2006 mercruiser 3.0 2 barrel carb help!
Oxenham1
Hello! First time boater here! I am mechanically i clined, but I need some expert help! I recently took apart the carb on the boat I got. Bought the rebuild kit, as it would just pour gas into the carb after a wide open run, causing it to stall out. Anyway, im into the carb rebuild now, but my problem lies in putting the ?main jets? back in the carb. There are 3 of them. One is stamped 170, and the other two are stamped 70. I have no idea which go into which openning. The plan was to disassemble and rebuild all in one day, but it ended up sitting for a week, and now I forget :( These are the 3 inside the float bowl, set at different angles from each other.
