constantin
- Aug 9, 2016
- 11
HI Guys
does it apply this issue for mercruiser 3.0l 2009 TKS carburetor?
I checked the TKS module with ohm meter and I measured something there but did not check with voltage.
I m happy for you Alexvelarde , finally I see somebody fixing this annoying issue.
Unfortunately it s hard to find good mechanics where I leave so maybe you guys can help me. My boat was serviced by 2 different mechanics and one of them gave up , the other one said it s fixed and actually wasnt.
The symptom is : starts pretty good when cold (IDLING ROUGH BUT IDLING ) running like champ when in speed, after that very rough idle( and stall) . If I try to start it when warm I cannot ( if I use the throttle 1/2 it starts right away).
I checked the electric plugs , distribution etc , the fuel line , carb , jets and the gas.etc.Nothing.
Now guys I saw this TKS topic and I was thinking maybe here is the issue.
It s idling rough most of the time , sometimes for few minutes maybe ok but it s bad in general.\
any advise will be very appreciated
Thanks in advance
Cheers
Thanks in advance
Cheers
