Changed all bellows, shift cable, shift shaft bushings and seals, water intake hose and lube monitor fittings and hose on Alpha 1 gen2. After one day in water the exhaust bellows popped off the gimbal housing. I followed the manual that seems to indicate application of the adhesive to the rubber mating surface of the bellows and wait until no longer tacky. The bellows adhesive package says to apply to both surfaces and let dry until tacky. Which is right? Could this be the reason for the failure?
