lilmandavis
- Mar 9, 2006
- 618
in my 87 contessa 2850 with the big 460, when i am running at 3200 and up, the temp starts to climb to around 200 when i ease off the throttle- it cools right off. when im idleing under 1000 under way it heats up as well. between 100 and 3200, it runs fine timing at 10 degrees. new impeller i can feel good impeller pressure out the litle vent on the pump housing, on the back of the drive shaft and dock side not under way i cant get it to overheat just underway?? will the bubbles in the coolant water be the prob from the exaust?
