Mark,
Your good! I will do my best to address your points/questions.
1: yes this is my boat and manufacturer, no on the elite model
2: i have a 15" transom, the motor is 20". the jack plate raises 5", i also increased it 1 1/2" with new holes, this includes mounting the motor on its highest setting.
3: If I can get a aluminum prop dialed in, then that will get me at a great starting point for ss. I will be happy to purchase the Hustler prop as long as i can focus on the correct pitch.
4: i called around my local marinas today in correlation of a new LU, no success. I'm on the market for a used 1:83, merc changed the LU design in 07.
5: i went with a 1:2 setup on the tach settings per a post I found in the internet stating a 4 stroke hits once per cylinder every two revolutions. Is this true, Im not sure! I cant stand behind the tach, unfortunately all I have is a diesel vehicles. I have the tach wire wrapped around my #1 spark plug wire.
6: im pretty sure the tach reads to 9999 rpms, i was lead to this style tach based off other "old" forums ive read.
Conclusion:
Im not certain of my tach setup at this time, i will get a friend to come over with his truck so I can get it dialed in correctly before my outing on monday.
I will be certain to get all requested info/pics for you. Thank you for your time and diligence! I will post some additional pics here is just a moment.
Richard
Going to walk down your list:
1 and 2. With No on the elite model, does the hull NOT extend past the engine, aka is a normal transom with the jack plate attached. If so, then your 1 ? inch extra, after your 5" plate adjustment to bring you to 21 ? is the way to go. Shouldn't need more than that.
3. Again, if you want to dial in an alum. the Hustler is the ticket. Right now what you need to know is what pitch and we are trying to solve for that.
4. If you are going to change LU, an OEM regular LU for the 60, 20" height should drop right in. You should do that before you spend any money on the one you have.
Let's say you do get a 1.83. Let's say your engine will run your lightweight boat up to 5500 rpms. Let's see what kind of pitch in a 10" prop that will take using a realistic 12% slip: Starting with a 19P your numbers are 54 max and 48 realistic.
Ha! Just what I thought. I go to the prop selector under Boats and Accessories at the top of the page and punch in your 2001 and above, 60 hp (non Bigfoot) and plug in the 19 and guess what? The selection stops at 17P. However, if I go back to the chart and punch in "with Bigfoot" the selection goes out to 26P As I assumed the 60 with a conventional lower unit is not made for light fast hulls like the higher hp engines that are running the 13" diameter props and up. Therefore you can't get to where you currently are
So, back to the numbers. Running your best in class 17P on your proposed conventional LU, 5500, 1.83, 12% slip = 48 mph in a solid, 42 @ 12% slip. You are better than that as you are!
This time using your current 115 hp 2:1 gearbox, with the max available 26P just for a data point, 5500 rpm = 68 mph max and 60 with the 12% slip. If your hp exceeds the drag sufficiently, you could do that with your current engine and a new prop.....but that number I'd bet is pretty optimistic.....You don't know till you try it, but I don't want you having "visions of sugar plums" when they are impossible to obtain.
Now, do you still want to pursue your standard lower unit?
5. 4 strokes have (1) intake cycle (? revolution), (2) compression cycle where fuel air is compressed another ?, (3) Bang and compression stroke another half cycle (4) exhaust stroke, last ? for a total of 2 complete revs for one Bang! 2 strokers just halve the numbers. Change all ?s to ?s and you do the job in one complete rev. 2 strokers put magnets in the flywheel and pickup coil on a bracket under the flywheel. On my 3 cyl the magnets were 120 degrees apart. Every rev all cylinders get whacked 3 times but only one occurs when the piston is at the end of the compression ? stroke. The other plug firings are wasted but no big deal.
If the 4 stroke is a conventional OHC design, the cam shaft, running at ? the crank shaft speed would be used to drive a distributor firing mechanism to trigger the spark plugs and that would be only one spark per pair of crankshaft revolutions per plug. If the 4 stroke uses distributer less electronic ignition with a separate coil per plug then the crankshaft will have a mark of some kind that passes a sensor and the sensor would fire the plugs every time the crankshaft rolled which would put a spark on the plug every rev and would be wasted every other rev since the camshaft would only set up the compression stroke valving every other crankshaft rev. In short you need to know.
However, as I indicated for you, where you are now, 7200 nor 3600 are usable numbers. They just don't fit the rest of the equation.
6. Great on the 10k max reading. You still need to run the calibration test I asked for using your car's tach which I see you will do on Monday.
