1. At the stern on both sides there are boxes built on the floor filled with floatation foam as you can see from picture 2,3 & 4. The foam ran all the way to the transom as well. I can only assume this was for both flotation and support? Question is, do I need to have all that foam replaced in that area? Since the foam is supported by the deck, two wood walls, and the haul wall, I would think I could support the transom in that small area another way and use less foam when the time comes to put everything back together. Or do you think I should replace it like it was and have the foam go all the way to the transom? just not sure that since the foam was adhered to haul wall as well, if it was doing anything there as well.
2. Stringers. As you can see, when I cut into the stringers they were wet. The stringers are a box type using the foam and a piece of wood sitting on top of the foam for support. The walls have no wood supporting them. So here is my question, which might sound stupid to those experienced builders. Can I cut the top off the fiberglass stringers, remove the wood and wet foam, replace with new foam and epoxy covered wood, and then fiberglass the top with new material to the existing glass sides? the sides are in great shape (minus the one side in the picture that I cut) and attached to the floor as solid as can be. In my very very inexperienced mind, I can sand the existing stringer wall so the new material will take. I figure if the fiberglass wall is already strong and has excellent adhesion to the haul, why mess with it. Will new material not stick to the old fiberglass stringer wall even if prepped?
Thanks for taking the time look over my post and guiding me in the right direction. I am trying to do this with minimum cost, but I also don't want to compromise the integrity of structural components.
