This may be a dumb question, but I'm trying to sort out some wiring issues on my new boat with a 1994 4.3L. The oil/water temp warning horn is not working and I'm trying to chase down a wiring issue (new alarm, confirmed I am not getting a ground signal from the signal wire with key on engine off like I should).
I've been looking all over the block and I have found the oil pressure cutoff for the fuel pump just above the oil filter, and the oil pressure gauge sender on the rear of the block by the distributor. I have no idea where the warning horn sender is however. Can someone shed some light on this for me?
