Mr Bondo, why cylinder 8 is the worst, please elaborate... also from my primitive knowledge lean condition means not enough fuel so issue could be with intake valve?
Ayuh,..... What induction system is on this 5.7l motor,..??
Carb,..?? Which carb,..??
Efi,..?? Mpi,..??
Boat motors tend to go lean from crud in the fuel system from the tank to the intake,....
Water, 'n sittin' alot contribute to this,...
When fuel can't be properly delivered, it goes lean, sometimes some cylinders more than others,...
It looks like piston pieces built up on yer spark plug, from detonation,...
If ya just fix what's broke, or go for a reman, the boat's side of the fuel system will still be Suspect,.......
